I gots Diesel Power!!!!
    Yea it diesel almost the same thing that a chip does except that most chips confuse the out put signal this just changes the input signal witch in the end does the same thing
      This one is def intercooled. not sure when they started putting them in but I would say ever since ford had a turbo diesel, not the non turbo version (which I think was called the IDI?) The first year of the turbo versions were still the IDI motor and they didnt do so hot. So they developed the powerstroke in 94 I believe which is intercooled.
      Dude theres definatly no intercooler anywhere.... Just looked it up 99 was first year
      95XJ tons 3 link 36s 5:38s
      97 F-250HD 7.3 Turbo Diesel
      "Shut up and Wheel"
        I've heard of the resistor thing as well. And my friend has a 93 IDI turbo dually. It's bitchin!
          You could get a idi or Turbo charged in 93. And PS in deisel it is called a aftercooler not a intercooler the only way that it could be a intercooler is if it is between 2 turbos
            Originally posted by WAD357 View Post
            Thanks guys! Got the lettering off it today ill snap some daytime pics clean tommorow
            Gunna have a full sweep of guages to keep my eye on everything also gunna install a transcooler the size of texas.Thanks for the heads up, however I learned the E4OD hates heat in my last f250 when it puked the main seal and the fluid caught fire on the exhuast 2 miles out on to the beach
            Its non intercooled think they did that with the 6.0 in like 2003 2004 ish
            the year they changed to the "powerstrokes" they became intercooled I believe so it was like late 97's and up
              for real?
                for real?
                fo sho no intercoolers till 99
                "Shut up and Wheel"
