and btw evan the size of the ring gear isn't whats important its the contact patch between the ring and the pinion, of you have a super low or high ring and pinion you have a bigger contact patch which will be stronger than standard for example a 9" gearset is just as strong if not stronger than a 60 cuz it has a greater contact patch because the pinion is supa low
suzuki samurai
So, if you customize a D35 to take D60 axleshafts and throw on a set of 37" tires, the gears won't explode as long as the contact patch between the ring gear and the pinion gear is good to go?Originally posted by XJtheXtremeJeep View Postand btw evan the size of the ring gear isn't whats important its the contact patch between the ring and the pinion, of you have a super low or high ring and pinion you have a bigger contact patch which will be stronger than standard for example a 9" gearset is just as strong if not stronger than a 60 cuz it has a greater contact patch because the pinion is supa lowsigpic
yesOriginally posted by Buffalo Phil View PostSo, if you customize a D35 to take D60 axleshafts and throw on a set of 37" tires, the gears won't explode as long as the contact patch between the ring gear and the pinion gear is good to go?
im not sure what his deal was but tons of yota guys run them on 40" tiresOriginally posted by HeavyMetal View Posttell that to jeff valentine
smaller-than-stock-XJ ring gears are not so cool
its how the gearset is made to contact, not resulting from the final gear setup process.Originally posted by Buffalo Phil View PostSo, if you customize a D35 to take D60 axleshafts and throw on a set of 37" tires, the gears won't explode as long as the contact patch between the ring gear and the pinion gear is good to go?
in general yes a larger ring and pinion will be stronger, but also a lower pinion making contact with more of the ring gear will also be stronger
So then why the fuck did Valentine nuke 2-3 sets of gears OFF the trail?Originally posted by Ktmracer419 View Postits how the gearset is made to contact, not resulting from the final gear setup process.
...And 'because he fails' isn't a valid excuse because we already know this.sigpic
the guy settin them up could suck at life.Originally posted by Buffalo Phil View PostSo then why the fuck did Valentine nuke 2-3 sets of gears OFF the trail?
or his pinion was rotated so much the pinion bearings couldnt get lubricated properly (lotsa lift on a tj= rotated housing)
