i would get armor and just a lunchbox for the front. arb's are so much $$
decisions
Originally posted by grundlepunch View Posti would get armor and just a lunchbox for the front. arb's are so much $$2000 xj 4.5 clayton longarms with wontons with a touch of
97' zj
2012 surbra imperza DD
Originally posted by hoggie101 View Postif i get an aussie front the front it wont look up when i turn corners right? because theres no imput from the ds itll only lock when im in 4wd also correct too?
Off road while turning your front wheels will lock together on slippery surfaces and you will simply plow with your front tires and go straight in 4.I highly recommend against front lockers without full on/off control and lock-out hubs and I would NEVER put any locker in a steering axle without lock-out hubs.
maybe that's just me?
Eric
Originally posted by WickedXJ View PostI don't get this so maybe I'm right maybe I'm not but as far as I have been told and seen for myself an auto-locker is designed to be engaged most of the time and disengage when enough torque is put on the locker by a difference in speed of on tire to the other, hence the clicking while turning? So since the drive shafts are connected to the wheels 24/7 with unit bearings doesn't this mean that it would lock irregardless of being in 2 or 4?
- right
- kinda you dont feel it when your driving around in 2wd.
- they will do the same if you have and open diff. the idea is TRACTION. 2 wheels spinning is better then 1. you get used to how a locker works quickly
- Why??? have YOU ever owned a jeep with a front locker? i had a lock-right in a d30 and though i did end up breaking it, it drove fine and preformed well offroad. and i currently have a detroit in a d44 and love it.
and lock-out hubs and I would NEVER put any locker in a steering axle without lock-out hubs.maybe that's just me?
- Again, why? lock out hubs provide obvious advantages (like breaking an axle or ujoint and still being able to drive home) but its not a necessity"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
