Clifford
  • Clifford
    The NEW Jeep.
    #becauseJoeNitro
    thats in alot better shape than your other one
      gonna keep this one red plz?
        lookin good, are you keeping both or?
          What are you doing with the front end?
            the paint on this will remain AS IS...
            i am not keeping both, the brown one will be stripped of its good parts and scrapped.
            the axles under the Red 89 are going to be taken out and returned to armand for his girlfriends xj. the axles/tires on my brown 91 will go under the 89 and the 33" claws in the pics are going on Christinas TJ .
            #becauseJoeNitro
              OK.
              specs....
              1989 Cherokee Sport 2door.
              swapped in 89 renix motor with 105k on it. (no leaks)
              2x3 L iron frame stiffiners.
              2x6 box steel rockers welded in.
              roll bar...? if you wanna call it that....
              new gastank/fuel pump.
              solid floors and unibody (no rust )
              my plans are:
              gastank tuck.
              long arm.
              good set of shocks all around. 5150's ?
              Raised rear shock mounts (on axle)
              5 point harnes
              workin on some plans for a mild front exo tied in from the front bumper to the sliders and then a tube fender off the rear bumper followin the wheel well to the sliders.
              all of this will occure b4 i switch axles from the 91 to 89. i plan on keeping the 91 on the road while i build this so i can still wheel. should be done late september early october...
              #becauseJoeNitro
                your plans are: keep red
                  That roll cage was in my truck... saved my ass, it works (well not all of it was in my truck but part of it)
                  1950 Willys Trail Rig
                  2007.5 Dodge 2500 QCSB 6.7 Cummins 68RFE 4x4
                    hey its better than nothing. And it's a good start so he can finish it later.
                      Decent start, keep it clean and simple.
                      RM
                        #becauseJoeNitro
                          AND eventually down the road....
                          #becauseJoeNitro
                            THE GOODS...
                            http://completeoffroad.com/i-3786489...ine-24110.html
                            http://www.eshocks.com/bil_ORsb.asp?...x=Q8&SubChar=Q
                            http://www.roughcountry.com/jeep_xj_689U.html
                            #becauseJoeNitro
                              the color sux
                              99 Dub Ya Jay
                              My Adventures Thread
                              http://sisoffroad.com/forums/showthread.php?t=15148
