will i need to get two sye's and two drive shafts when i put my 3.5 susp. lift on or will the sye by them selfs work?
sye and new drive shafts?
Do the lift, then if you need the sye then get it. Every experienced mech. tells me, if it doesn't need it, then leave it the way it is.God made the world in seven days, on the 7th day, he made the Le Car
Especially with a wrangler, the shaft is so short that as soon as you start going up that driveline angle is immediately affected by it. I went through two or three shafts before i smartened up and got and sye and a tom woods.1981 CJ8 - old & dumb
2001 TJ Sport - DD
I would do one to be safe and it is not that expensive at 175 bucksP8R
i ran my TJ on 4" lift and would get some vibes at 70+mph from the rear driveshaft without SYE but did have a skid plate drop spacer on it but otherwise it was ok. ate a u-joint every so often although my driveshaft isnt exactly it the best shape ever since i grenaded my t-case output shaft + rear yokeup to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
Do your kit and if you need to you can simply get a transfer case drop which can be only $20. This way you won't have to take time out to wait for an SYE. and if you want an SYE then you can simply take out the transfer case drop and put on the SYE. You can even make your own t-case drop with a pipe and 4 longer bolts.Jeeps don't get stuck ... they just take a nap when they are tired of being awesome
Eric
Originally posted by hoggie101 View Postha for 500 ill just get an sye and a tom woods
Muffler Bearing
Halogen Light Fluid
Tire airatorsHench
