electrical issues on a tj
  • electrical issues on a tj
    im having some electrical issues lately with my tj. first off my blinker indicator on the dash stays on all the time for the left side blinker. i have a loose connection on the front left blinker light but will this matter for that? it just started doin it tonight so idk. then when i flipped my auxiliary switch for the rear wiper the beep sound that goes off when you leave the headlights on and open the door or leave the keys in started going off the whole way home. that seemed real weird to me. each day its been doin some new weird things so ill update if anything else happens but in the meantime does anyone have any ideas on how to fix this?
    check all your grounds. sounds like that loose wire in the front could be the source of the bad ground
      and you think you have electrical problems! haha
      im not sure how to fix yours, but good luck.
        On a lot of newer cars, the indicator will stay on if you have a bulb out as well. Thats something to check. As for the beep with the rear wiper, your on your own, haha....I hate electrical! Maybe a ground?
        2006 Rubicon - high rock bumper, warn 9.5ti, and lots of stockness....for now...
          just get rid of you blinkers and just use the light bar aka THE SUN to signal
          -54 Dodge Power wagon M-37
          -57 GMC Pickup
          -Tim (OIIIIIO)
            99% of all electrical problems are with the ground.
            with that said they are right about if a bulb is out the indicatior staying on, but idk about the beep could be a crossed/nicked/shorted wire sending power to the wrong/more than one things? check wireing to all things involved with your issues
            #becauseJoeNitro
              [QUOTE=JoeNitro;18873] 99% of all electrical problems are with the ground. [QUOTE]
              That seems to be a bit of an exaggeration. I call BS
