i was wondering if i would just be able to put a bigger coil in my jeep than i have... i have a 4 inch lift and was wondering if i can jus change the coils... also what would be the cheapest way to get more flex out of the suspension... i currently have jks quicker disconnects in the front... jus wondering if theres anything else i can do... thanks again
can i just put bigger coils in?
If your tires are mashing into your jeeps body there isn't any more uptravel to squeeze out. Adjust the bumpstops so that the tires stop immediately before hitting anything.
As for shocks, bilsteins are always a good investment. Rubicon Express monotubes are also pretty good.
Originally posted by fullwidthxj191 View PostIf your tires are mashing into your jeeps body there isn't any more uptravel to squeeze out. Adjust the bumpstops so that the tires stop immediately before hitting anything.
Bumpstops limit UPWARD travel, you clearly want more flex, so limit the upward travel a bit and get more DROOP which is DOWNWARD TRAVEL.sigpic
