sounds like power steering in reverse
  • sounds like power steering in reverse
    when i reverse this sound like a power steering pump whining happens....... have no idea where it's coming from though. guh?
    does it make the sound just sitting still? or only when you are moving? and why don't you have someone pop it in reverse and hold the brake while you listen around the vehicle and under the hood for where it might be coming from if it does it sitting still.
    -Ryan
    Rigs:
    07 Toyota Tacoma, 4.0L V6, 6spd Man., 3" Susp. Lift on 33x11.5" Mickey Thompson Baja MTZs, Plenty of Light and Exhaust mods too - SOLD IT!!
    94 Toyota Pickup/w'93 yota body, 3.0L V6, 5spd Man., Body swapped, Removeable Doors, Rear Locker, 36x13-16 Bias TSLs on 16x7" steel wheels, rock sliders, Custom bed and start of Roll Cage
      rear pinion seal? had almost the same thing happen to me, only really noticeable going slow in reverse
      1992 xj Briarwood
      Welded front and rear
      13' LED roof lights
      Disco ball
      Truck nuts
      Spinners
        Maybe your front pump is going out. Your highest line pressure is when you're in reverse so that may be why it whines then.
