Is there a flatter T-case skid that doesn't require BL?
  • Is there a flatter T-case skid that doesn't require BL?
    As the title asks; Is there a T-skid that isn't a shovel that doesn't require a body lift? I would like to give my jeep a slimmer figure without having to go with any more lifts.
    Shane "The Bag" Carlson
    My "Bucket" Build
    MilitaryJeepers.com
    ‚——P--;===±--= <-
    !‚–’¯ƒ¹¶
    I believe you can clock the Tcase, never done it myself but heard/read about it
      33 engineering has a nice belly up
      might require a 1" body though, dont remember
      but all i know is if i had a tj thats what i would do
        I believe Mad Rooster on pirate is still making clocking rings for the np231. You could always try a 1" M.O.R.E motor mount lift and the chance to cut up some floorboards may show itself if you don't want to add the bl. The belly up skid from tera flex is a nice product although more times than not it does require about a inch of bl to compensate for the skid.
        Here are some possibly ideas that others fabricated. Post #36 looks interesting given its a grand cherokee and not a tj. Do you think you would be interested in possibly cutting your stock skid, plating the low areas that were cut away and skinning it with uhmw?
        http://www.pirate4x4.com/forum/showt...=733408&page=2
        http://www.4x4wire.com/jeep/tech/frame/tjskid/
        http://www.4wheelerssupply.com/catal...95843a996132af
        RM
          Thanks, but.....
          Each one of those says I would either need a T-case drop, or BL/MML.... I'm just wondering if there is something that lets the T-case/tranny sit in the same place, but more beefy, and has some kind of beveling/angle instead of a downward facing lip so I can slide over, not capture rocks.
          I just don't want to go with a BL, and figured that someone would have made slider to directly replace the stock skid without needing any other adjustments.
          My "Bucket" Build
          MilitaryJeepers.com
          ‚——P--;===±--= <-
          !‚–’¯ƒ¹¶
            http://claytonoffroad.com/product_in...roducts_id=192
            I think this is about the best youre gonna find without going with a lift of some sort. only .5" gain tho.
            at least its smooth
              Not bad.... I'll give Nica a break, but this is now on the list.
              My "Bucket" Build
              MilitaryJeepers.com
              ‚——P--;===±--= <-
              !‚–’¯ƒ¹¶
