Tranny issue
  • Tranny issue
    Just wondering if anyone has had this problem and what they did to fix it..My GF's 98 cherokee is not shifting back down into 1st when it comes to a stop..But it will shift normally when shifted manualy.. I know for a fact the neutral saftey switch is bad..I have like 3 codes for that right now and its grounded so the Jeep can start..So I'm thinking either that switch is really on its way out or the tranny has a bad selenoid..Any insight from anyone would be appreciated thanks.
    What are the codes?
      PO705 and 1698, I got the ame codes in my 99 when the NSS got filled with water.
        sounds like a bad solenoid if you can shift it manually
          Replace or Rebuild the NSS and clear the codes. That might fix your problem.
            not to be captain obvious
            but adjust the kickdown cable
            i have had them slip on me and cause the same issue
              You could check solenoid resistance at the tcm if you have something to show pin location like a repair manual. It is right under the dash on the driver's side of the center console.
              pork chop sandwiches
