i am on my second seal on the cone and it keeps leakin everytime i check the fluid level it comes pouring out wat can i do to stop this thing from leakin? i cant figure it out i wont be bring it to the meet and greet and the honda will be comin again
sye problem
Which seal? the the rear output?
Is it leaking out of the splines/center of the yoke?
Between the Yoke and seal?
Between the seal and the housing?
Or some wheres else?RCrocs #123 Brown CJ-5
Originally posted by clean4drxj View Postdid you lube the seal before assembly?Use transmission assembly lube or petroleum jelly/Vaseline.Originally posted by tomatoboy View Postwat should i of lubed it with
Both will melt in the transmission fluid/oil.
If you use normal grease/wheel bearing grease the grease doesn't melt and you end up with globs of grease floating around.
Not the worse thing to happen but trans jelly works best but if you ask for it at an autoparts store they will look at you like you have three heads so order it on-line.RCrocs #123 Brown CJ-5
ok sweet thank you for all of ur help means alotOriginally posted by customcreationsllc View PostUse transmission assembly lube or petroleum jelly/Vaseline.
