sye problem
  • sye problem
    i am on my second seal on the cone and it keeps leakin everytime i check the fluid level it comes pouring out wat can i do to stop this thing from leakin? i cant figure it out i wont be bring it to the meet and greet and the honda will be comin again
    is the seal surface free of grooves, any kind of play in the shaft?
      nothin and it is a new kit i have maybe ran it like 220 miles
        did you lube the seal before assembly?
          wat should i of lubed it with
            just use some grease(waterproof) in the seal and you don't have to glab it in, just a lil
              Which seal? the the rear output?
              Is it leaking out of the splines/center of the yoke?
              Between the Yoke and seal?
              Between the seal and the housing?
              Or some wheres else?
                it is the rear out put seal it is leakin between the seal and the yoke
                  ok i will try it thank u
                    Use transmission assembly lube or petroleum jelly/Vaseline.
                    Both will melt in the transmission fluid/oil.
                    If you use normal grease/wheel bearing grease the grease doesn't melt and you end up with globs of grease floating around.
                    Not the worse thing to happen but trans jelly works best but if you ask for it at an autoparts store they will look at you like you have three heads so order it on-line.
                      ok sweet thank you for all of ur help means alot
