bilstein..?
  • #31
    I think your best bet would be to measure shit up after you bumpstop and trim, then see if you have enough room for 10's.
    • #32
      i might have to, though i have no shocks to run till i get money for new ones
      • #33
        Originally posted by Burton58 View Post
        i was going to make a thread about this seeing as i want to get 5150's. thanks for saving me the trouble joe.
        looks like 8" travel all around is ideal for 3.5" lift?
        basically (with stock mounts)
        Originally posted by JoeNitro View Post
        i think im going to go with 10 front and 8 rear because im going to make high clearance rear shock mounts...
        at 4" o lift and 8" shocks with high clearance mounts i bottomed them out constantly and broke some parts
        Originally posted by Even View Post
        Sam can correct me if I'm wrong, but I'm pretty sure he ran 10's on 3".
        I guess it also depends on what tires you plan on running, because that will effect bumpstops.
        only in front
        now i run stock length in back
        my mounts are pretty much as low as you can go on the axle tube
        • #34
          i'll be running stock mounts as well. 8" it is....
          • #35
            • #36
              otay bumping this. if i get the bilsteins i'm gonna need these gobshites up front right? rear should be good to go?
              just double checking
              • #37
                correct.
                • #38
                  gracias mi amigo
                  • #39
                    itlooks so nice out in RI.
                    Is it egg nog season yet?
                    • #40
                      these.
                      http://www.polyperformance.com/shop/...ocks-p-84.html
                      you wont do it
                      • #41
                        Originally posted by SwampThing View Post
                        Those are some nice big black cocks.
                        • #42
                          that was taken like months ago lol
                          • #43
                            those.... driver side for me was a bitch and a half, they give you the nuts with the poly HMDFTQKEODLEKDIV in them. and trying to do it without and extra hand or a large enough socket blew massive monkey nuts.
                            i thinks i needs to order me some bilsteins real soon.
                            • #44
                              bling bling option
                              http://tandjperformance.com/store/in...&products_id=7
                              • #45
                                teraflex ones are 5 bucks cheaper than the jks on qtec. they are the same damn thing
