gear ratios for swaps
  • gear ratios for swaps
    when looking into doing axle swaps, the gear ratio should be the same for the axle you swap in to avoid paying to gear it up. now the question: i have a 4:10 ratio, and i see dana 44s with a 4.11 ratio. is this the same? will a 4:10 front and 4:11 rear work? it might be a dumb question but i wasnt sure.
    It will be fine.
    As long as you are within X:X1 - X:X2 it will work.
      Originally posted by Even View Post
      It will be fine.
      x2
        thanks guys, wasnt sure how that worked out
