Fluid in Extention Housing
  • Fluid in Extention Housing
    Going to be swapping the blown 242 tcase in my 98 my question is I've noticed before when dropping some Tcases at work there is fluid in the extention housing... Is this fluid out of the t case or trans?
    95XJ tons 3 link 36s 5:38s
    97 F-250HD 7.3 Turbo Diesel
    "Shut up and Wheel"
    Some transmissions have extension housings to mate the transfer case up, Borg Warner T18 to a NP205 for example. It's important to know where the seal(s) are located to better identify which fluid it is. On a 242, it's transfercase fluid since the extension housing is on the back of the tcase.
      Thank you sir Just trying to make sure draining the tcase will help make less of a mess
      "Shut up and Wheel"
