Randomly, my XJ will blink the check gauges light and the temp gauge will spike. It goes away sometimes if i turn on the heat and blast it, but after it does this, if i turn it off then crank it again it skips and lopes like it thinks it's a big block. coolant is full, oil doesnt have water. anyone have an idea what it could be?
Oerheating/running like crap
my legacy did this for awhile, the temp gauge spiked and went back down. it didn't seem like it was overheating though. it started stalling like yours. after 2 weeks it wouldn't stay running. turns out the head gasket had a pinhole that got worse till it was blownI drive a Datsun
colant temp sensor? for the loping problem maybe? Id flush the cooling system and run some regular green in there its supposedly bad to mix the different colored ones. Could also be a bad thermostat causing brief overheating..89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
Times too on the head gasket, if I turns out that's what's up it's really not all that bad, I'd be more than willin to lend a hand.
Also, my old BMW would do the dame thing, erratic temp spikes with CEL (or BMW equivalent) turned out it was indeed a blown head gasket, just a small leak that would cause a pocket of superheated air to cycle in, and when that air hit the temp unit it would freak the fuck out...dirty30
