so..
  • so..
    ok, now im having windshield wiper problems. my wipers get stuck on the drivers side. like for some reason the drivers side one goes off the windshield and gets stuck on the pillar.. is this a motor problem? i have the normal size wipers they call for but it started doing this a couple weeks ago. i didnt think much of it cuz it wasnt doing it often, and now it happens like every other wipe. how hard is it to swap out the wiper motor? i can pull one out of the junkyard for fairly cheap probably so any input would be schweet.
    i was all ready to share some tech and good cheer
      Well maybe you can. Is it true that 4 cyl 2.5 xjs came with 4.10s?
        i think any 2.5L came with 4:10's
          but only with D35's unless im mistaken
            yarp, true it be...... a 4 cyl, 2wd or 4x4 5spd mj will have 4.10's...... a 4cyl, 4spd 2wd or 4x4 mj will have 3.55's.. and theyre rareish, but i believe 91-92 4cyl 4x4 automatic mj's came with 4.56's....
            "Life's tough, but it's tougher when you're stupid." John Wayne
            88 Jeep Comanche 4.0/AW-4/NP231/D30/D35
            95 Chevy K1500 ext. cab 350/4L60E/NP208
            91 GMC Sonoma 2wd 4.3/700R4 (gotta have something that gets good gas mileage!)
              Originally posted by WBkrazy View Post
              yarp, true it be...... a 4 cyl, 2wd, 5spd mj will have 4.10's...... a 4cyl, 2wd, 4spd mj will have 3.55's.. and theyre rareish, but i believe 91-92 4cyl 4x4 automatic mj's came with 4.56's....
              very uncommon, but yes.
                nope
                  Ok cuz i want an 8.8 in the rear and 4.10s in both so if i get a d30 from a 2.5l and an 8.8 ill have what i want for 33s. Then i can lock the 8.8 and all that fun stuff.
                    nope
                    Enlighten us sam..
                      Originally posted by 93XJRay View Post
                      Enlighten us sam..
                      basically that
                      ax5= 4.10
                      ax4= 3.55
                      aw4=4.56
                        for your steering you could do waggy steering for cheaper
                          really? whats the difference between the components? like the full size waggy or like yours?
                            converts it from y link to t link, full size waggy. bigger tie rods, can be picked up for 30 bucks or so. still need to ream knuckles though
                              to reaming knuckles. thats a pain in the sack isnt it? especially if something does go on them?
