Whats the difference between a full spool and a locker? Is a spool just 100% locked all the time?
Spool vs locker
A spool is always locked. A locker locks when a wheel slips. Spools are cheaper but cause increased tire wear and make your tires chirp when taking turns on pavement.-Caleb
not how a locker works.Originally posted by Bigbike View PostA spool is always locked. A locker locks when a wheel slips. Spools are cheaper but cause increased tire wear and make your tires chirp when taking turns on pavement.- Will
lunchbox lockers, like an aussie or no slip, will unload around turns and ratchet so you dont chirp the tires, but when power is applied they lock. these just replace the spider gears.
a full case locker like the detroit is not always locked either(i think), however, these replace the whole carrier
selectable lockers like eaton e-lockers or ARB can be either an open diff or fully locked by the flip of a switch, hence why they are called selectable. ARB's are powered by air and e-lockers are,well, electric. these also replace the carrier and spider gears
a spool is just a thing that replaces the carrier and is a solid piece of metal pretty much. It is locked 100% of the time. looks like this
http://www.4wheelparts.com/Drivetrai...5589&t_pl=2213
hows my aim?P8R
there are spools that replace the spiders as well, mini spools
detroit is not always locked like u thought
easy way to describe a selectable is a spool u can turn off and on- Will
right, forgot about mini spools, thats what we just put in the tracker too
That would be the eaton g80 limited slip differential. It tends to make gm 10 bolt axles grenade in certain situations. I had one in the burb, that thing was bad ass.Originally posted by Jeep Creep View Postwhat about the sweet locker doo hickey in my dads chebby. it locks when it senses wheel spin according to chebby.1993 XJ sport 3.5" rustys 33" MTZ's armored.
