Does anyone know where I would be able to get these? Would it be possible for me to cut my old ones off and reuse them?
Unibody side control arm mounts
Originally posted by XJLI View Postoh good call. my bad for not reading.
welding a real 3/16-1/4" thick mount will need to go onto a stiffened body
ahh ok yeah I dunno how far up they went.1993 XJ sport 3.5" rustys 33" MTZ's armored.
Originally posted by Bigbike View Postget some long arms.
http://www.ruffstuffspecialties.com/...8-14-p-96.html
would something like that work?1993 XJ sport 3.5" rustys 33" MTZ's armored.
Originally posted by Hydra View PostWhat if you did some mid arms like Sam ran on v2.0, it would bworth throwing thr money into1993 XJ sport 3.5" rustys 33" MTZ's armored.
personally i'd do a stiffener type deal, weld 3/16 to the bottom of the unibody rail and both sides, then make the new mount out of 1/4 and just weld it right up.No worries, I'm not actually back, I'm just reminiscing about the old days.
Originally posted by greenxj513 View Postpersonally i'd do a stiffener type deal, weld 3/16 to the bottom of the unibody rail and both sides, then make the new mount out of 1/4 and just weld it right up.
lol
ANYWAY
get these
http://www.ruffstuffspecialties.com/...ket-p-125.html
and get some 1/8-3/16" plate
drill lotsa holes in there.
significantly cover up/reinfoirce where the old mounts went then weld these to those as close to stock as you can.
the stock mounts are glued/bondoed/spot welded to the jeep, and while i suppose you could just weld some stock cut up brackets to it, I will never trust it and it is mucho lotso work.
