Unibody side control arm mounts
  • Unibody side control arm mounts
    Does anyone know where I would be able to get these? Would it be possible for me to cut my old ones off and reuse them?
    upper or lower? you can get lower ones (front and back are the same) at a hardware store. the upper UCA ones have that ear or whatever on them bc of how theyre in the unibody and shit... prob dealer only.
      He totally means the mounts not bolts
      idk where to even start with those, if you've gotta weld new ones on do something like Sam did
        oh good call. my bad for not reading.
        ruff stuff, BTF, etc make universal mounts, but the stockers are like welded/bondo'd on all gay like.. welding a real 3/16-1/4" thick mount will need to go onto a stiffened body
          oh and right, patrono's jeep.
          idk if the stiffener goes that far in... my knowledge ends here.
            yeah that's already done, not a problem
            ahh ok yeah I dunno how far up they went.
              get some long arms.
                Originally posted by Bigbike View Post
                get some long arms.
                Can't. Too poor.
                http://www.ruffstuffspecialties.com/...8-14-p-96.html
                would something like that work?
                  What if you did some mid arms like Sam ran on v2.0, it would bworth throwing thr money into
                    I don't know what those are, nor do I have the equipment or know how to do anything but stock shit with suspension linking.
                      any of you welding guys have any input on welding to the unibody?
                        personally i'd do a stiffener type deal, weld 3/16 to the bottom of the unibody rail and both sides, then make the new mount out of 1/4 and just weld it right up.
                          I like this idea. the stiffener is already there, but I'm not sure exactly on where on the frame. But even if it is there, I say do what matt said. I think thats going to be your best bet. and it will make it stronger than stock flimsy mounts
                            3.0
                            lol
                            ANYWAY
                            get these
                            http://www.ruffstuffspecialties.com/...ket-p-125.html
                            and get some 1/8-3/16" plate
                            drill lotsa holes in there.
                            significantly cover up/reinfoirce where the old mounts went then weld these to those as close to stock as you can.
                            the stock mounts are glued/bondoed/spot welded to the jeep, and while i suppose you could just weld some stock cut up brackets to it, I will never trust it and it is mucho lotso work.
                              So drill holes in the plate that I get so that I can spot weld in the holes? In addtion to welding around it of course
