So my 98 head doesnt have a place for the gauge sending unit. where do i put it? sam said in the thermostat housing but i dont see how. please share and pics are super duper
Temperature sending unit
I thought that the one I was thinking of was the temp. control sensor, thanks for clearing that up.Originally posted by crosbike View PostThe one in the t stat housing is for the computer. There is another one in older jeeps for the gauge in the instrument cluster on the back of the head.I don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
so you are using a stock one or putting aftermarket one in? renix ones are on the back of the head and some are on the side of the block
they are sposed to go in the back of the head.
But I had my thermostat housing out and drilled a hole in that. there is a flat circle part on the front I drilled and tapped for one.
I THINK i had higher temp readings with it here than normal though because it was on the coolant coming out of the engine (hottest it gets) and not coolant in teh middle of the engine.
leave it out ? all that will happen is your temp gauge wont work on the dash... or drill and tap a hole like sam said.Originally posted by crosbike View Posthokay. i dont have that sensor hole by the exhaust manifold. any other ideas?
I guess you could always pick up a small piece of metal/plastic pipe and hose clamp it inline somewhere and drill a hole in that instead
my 95 GC has a 91 XJ motor in it and ran into the same issue, I just left the sensor out....up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
For when all else fails
http://www.steigerperformance.com/dif.cgi?sp4000289XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
95XJ tons 3 link 36s 5:38s
97 F-250HD 7.3 Turbo Diesel
"Shut up and Wheel"
dang i never knew those existed. i can totally make one of those easy peasy if my current set up fails. Well i tapped my t-stat housing on the bigger hose side and have about 1/32 clearance between that and the fan haha.Originally posted by WAD357 View PostFor when all else fails
