yay or nay???? one of my sealed beams went out tonight and i figured i might as well upgrade. the autopals any good?
autopal headlights
ive heard they dont fit good and the bulbs they come with blow real quick. my wagner silverstar-esc sealed beams with the upgraded wiring harness is more than adequate now, the high beams are worlds above what they used to be with just the harness upgrade
I think that is fine. I've never had a problem seeing at night with stock harness and silverstarsOriginally posted by Pete View Posti have my own harness i made with relays for high and low beam. i might just buy 2 new sealed beams and be done
If you have bad enough vision that this is worth spending money on, don't drive at night.Originally posted by greenxj513 View PostIPF H4 headlight conversion
i got the autopals. at first i was like this is what all the hype is about. the high beams didn't work and the housings themself were for some reason still loose after tightening them down as much as i could. but they settled into their spot and somehow tightened themselves and i played with the plug and if u get it on the right spot the highs and lows work. as for brightness. there better. low beams light up everything infront of you amazing with a sharp cutoff and high beams light up a mile down the road, but not as bright as the lows light up. i haven't gotten decent not indonesian crap bulbs yet tho2 tj's
