Which would you get??
  • Which would you get??
    I have the opportunity to work a trade with a jeep shop, advertising promo work for jeep work.
    A cage, or unibody stiffeners. (not talkin just TNT deals, i am saying front, middle, and rear unibody rail plating.)
    My unibody up front around the steering box is stressed and cracking a bit, and i know this is the sign of more to come.
    So it is either cage to stiffen the whole jeep in general (not really the front end), not to mention having a frickin cage to protect myself and my jeep to some degree.
    Or, having my unibody rails all welded up and stiffened, cracks that are forming averted.
    I guess I will do both no matter what, but what should I do first? Whatever one comes second probably wont be terribly soon.
    Yes, I'm aware before anything is done, the unibody needs to be straightened because it is tweaked, spare me that much.
    26
    An interior cage
    26.92%
    7
    Unibody plating/reinforcing
    73.08%
    19
    plate first
    then cage
      plate first
      then cage
      x2, get the unibody squared away before anything
        thats a hard decision, you could plate it yourself with nothing but a welder. but you don't have a bender, so I'd say get the cage then stiffen up the frame yo self.
        edit: cause u deff need the frame stiffened first, do that, then use your free pass for the cage. better deal IMO.
          Plate first.
          Any sort of cage worth doing, you are going to want to tie into your uni-frame rails some sort of way.
          IMO, doing a cage first, followed by frame plating would be bass ackwards.
          My frame of mind would be this: If I were to plate my unibody and roll, I can always chop up the jeep and start a sique trail rig project. If my unibody falls apart, I'm back to square one with another jeep. If that makes any sense at all.
            plate
              Unibody Plate.
                plate it, plus ill have a bender soon
                  My thinking is the price difference if you did it yo self...
                  Cage( depending on elaborativeness) <$1000
                  Plating >$300
                  Do the plating yo self. then have them do cage.
                  http://www.rocdogfab.com/index.php?o...id=9&Itemid=59
                  2013 F150 fx4 (Tow Pig/DD)
                  • 5.0 with the 3.73 option
                  2003 TJ Rubicon
                  • 4.0/42rle/np241or
                  • 5.13's
                  • 33” BFG KO2s
                    Plating >$300
                    I would think that a cage would require more time and $ so I would have them do that.
                      ^^^^ that is what I was trying to get at.
                      I screwed up the first time... I switched around the "<>' signs to read correctly...
                      2003 TJ Rubicon
                      • 4.0/42rle/np241or
                      • 5.13's
                      • 33” BFG KO2s
                        when i do it i want it to be beef as fawk
                        and if i tie in a cage to stock sheetmetal framerails i wont be happy.
                        i want to tie it into a dookinass plated framerailageness.
                          plate, not only for all the reasons above, but I also know your pure hate for off camber positions and dont really see you using the cage soon IMO.
                            do the plating yourself. then have them do the cage later on. It will save you money in the long run
                              LOL Cage first if they are going to do it. Caging it will be more labor intensive and more costly with tubing vs. plating which is very cheap and you can do that yourself in your driveway.
                              (not saying you can't build a cage in your driveway, well, cause you did!)
