Ok this is something that has driven me fucking batty for a year now with the XJ.
At some point, my brake pedal developed enough play in it that sags enough to where the brake lights come on, unless you pull up on the pedal. Theres the little piece there that i guess is the piece the position sensor is connected to for that, where if i space it up with washers off the pedal enough to be higher, itll keep the brakelights off and make it work correctly, but i have tried epoxy there and other such methods and it eventually always comes apart and the problem persists.
Why the fuck is this play in my pedal and what can I do to fix it? Is there some bushing there that is toast that I can replace? or something i can tighten somewhere?
Maybe I should just have a fawking washer welded there, but it seems like a retarded way to fix it.
