98+ door removal
  • 98+ door removal
    i am in the process of fabbing up my own tube doors and i wanted to know if anyone has removed doors on their 98+cherokees and how they did it. i know that this was the year that jeep changed the door hinge design. ill keep looking around for write up's.
    .,=====o00o ______________
    //___l__,\____\,___ ____
    l_---\____l----[]lllllll[] _
    _(o)_)___(o)_)--o-)_)
    http://www.jeepforum.com/forum/f11/r...ite-up-408138/
      Im going to be doing this when it gets warmer.
      aka Ill buy someone some beer to not fuck it up and help me.
      Is it egg nog season yet?
        Tis easy, just cut and bang out the old pins, and makes removable pins, if I coul do it again, i'd keep the stock brass bushing and use a smaller pin, whereas I ditched the sleeve and drilled the hole out, :shrug: oh wells
          i cut the old pins out tonight, so tommarow ill head out to lowes and look for some quick pins or hitch pins
            just be careful when you cut it or your door could fall off and than you have to weld the mount back up and the door doesnt line up right again it happened to me....two door doors are heavy
              i need to do this soon as it warms up
              Dizz dizz go sleep sleep
              Driver 4677 FSM vehicle
                I have mine removed on my '00 but they sag. Its because the pins dont fit perfectly anymore because the hole for the hinge on the car lost the bushing that goes in it. I think I am describing the accurately. Does lowes have something that drops in that can make a hole smaller?
                -Matt
                Facebook
                  well idk about making the hole smaller, you could buy replacement bushings to put in the hinge, but i dont think theres anything out there that can make it smaller. what i did was buy 3/8 x 3" cotterless hitchpins and just drill out the hinge a little until it fit snug.
