Coolant in the Oil
  • Coolant in the Oil
    Not sure how i should approach this problem. A mechanic confirmed that the coolant was going into the oil. To give you an idea of how faster. In 24 hrs a full overflow container gone plus the amount in the radiator, basically dry. Any ideas??
    4x4 Station Wagon...
    Is this in your TJ?
    Some intake manifolds gaskets will leak coolant into your engine oil but I'm pretty sure the Jeep straight 6 will not.
    Sometimes it's a head gasket but they usually don't leak coolant into your oil,
    Worst case a cracked block or head.
    But that is a lot of coolant is it all going into your oil?
    Get a coolant pump and try to figure out where it is leaking from.
    If you cannot find any external leaks start taking it apart.
      yea its in my TJ with the 2.5L
        so i just finished talking with the mechanic. He thinks Im going to need a new head and a gasket kit.
          to bad its not a 4.0 i have a head and gasket, intake mani gasket, lifters and push rods for sale
            yea that does suck... does anyone know where to look to buy these parts. I've looked around a for a while and cant seem to find what im looking for
              head gasket kit? napa, autozone, oriellys, levines
                jasper?
                  sorry i should"ve read further into it... I'd say napa for the gaskets
                    If you have been driving it and still are, im sure the bearings are wiped or will be shortly.
                      DON'T FUCKING START IT!!!!!
                        time for a rebuild or new engine antifreeze (glycol) ruins an engine cause it resists oil causing no bearing lubing causing hot spots and spinning your bearings
                          Get rid of good running 4.0 xj to buy a 2.5 TJ with a blown headgasket. Makes sense. O and I saw your old XJ the other day in Southington.
                            well actually the Xj needed alot of work apparently, The guy who bought put like 750 into a week after i sold it because it wasnt running, not sure what it was.
                              I seen your old xj for sale on craigslist
