CPS newbie
  • CPS newbie
    so i need to change out my crank position sensor, however i haven't changed one out yet. found it and all that good stuff, have a replacement one. my question is whats the easiest way to change it out? its in a bit of a tough spot to get to, any help is much appreciated
    -00 XJ. 3.5", 33s. Stuff
    -Ian
    i usually can get to it from the top of the motor if not use a long extension and a swivel socket
      Its a pain in the balls no matter what you do. Prepare to spend about an hour with your hand down there behind the engine. Good luck
        an hour are you serious? 10 minutes top
          Ya if you got little baby girly hands...
            no if you know what you are doing/ have the right tools
              yeh.. bout a ten min job.... use about 3 feet of extensions and a swivel...
              go from the cross member to the 2 bolts on the cps....
              also its nice to have a friend reach from the top guiding in the bolts while your underneath...
                alright....also i have a haynes manual and it said that the cps also sends info to the computer about fuel pressure etc....think this could constitute to my 10mpg maximum? since i plugged it into a scan tool and found the o2 sensor was sending relatively normal levels back to the cpu. and is that an hour to take it out or for the whole process?
                -Ian
                  its really not that difficult. 15 min tops. Be careful not to drop the bolts into the bellhousing on accident.
