so my jeeps been down due to a blown rear end. I got a complete axle and swapped in basically everything besides axle shaft's and pinion gear. Goes down the road accelerating/on the throttle just fine, but coasting/slowing down loud howling. I used the spacers from the doner axle as mine broke during bearing blow out. so my question is, obviously the howling is because the spacing isnt correct between R&P.... now if thats the case, is there a place that sell's different thickness spacer's and which way does it need to be moved ?
now im just guessing thats what the howling is from since it only does it while coasting (pinion riding on other side of ring gear) . I have little to no experience in setting up gear's so more experienced users please chime in. I did all this outside tonight (12 degree's out) so i didnt feel like tearing it all back down
