Are stock sway bars for the front of an xj the same length as ones you would need for a 4.5" lift?
Sway Bar ?
Originally posted by MdgtRac View PostAre stock sway bars for the front of an xj the same length as ones you would need for a 4.5" lift?Originally posted by Ktmracer419some people choose video games
the sway bar itself doesn't change, your stock end links(the part that goes from the axle and connects to the sway) won't be long enough.
To alleviate this problem you can either:
1. make longer sway bar links
2. Buy a set of extended ones for your lift height with disconnects
3. run no front sway bar
what lift are you running? some 4.5 in kits come with extended sway bar links that have a disconnect feature, like the Rubicon Express kit for example.No worries, I'm not actually back, I'm just reminiscing about the old days.
