theres a junk yard in mass that has a rear jk 44, i took their front for 1200 bucks he said he would do 2100 if i took both but didnt need both so i bet he still has the jk rear, but they dont bolt up from what ive heard..... pm me if you want the number (its a rubi jk so 4.10 locker 32 spline)
WJ rear axle options, what do you guys think...
i eventually plan on 33x12.5 and i really dont want to go bigger because it starts getting stupid looking on the WJ when you have to hack up everything...Originally posted by grundlepunch View Postwhat size tire are you planing to run?
this is where i want to be...
ill probably look around for the cheapest price for an 8.8 around here and probably buy it within the next few months and just slowly work on it and do whatever i can do myself on it and then find someone to finish it and put it in....-Jason
99WJ 4.0
If anything doing an 8.8 will be narrower in the rear. I don't see why going to a super 88 would make it wider, the housing itself is still the same.Originally posted by lakailimited06 View Posti also heard adding the super 8.8 kit increases the width? i really know nothing about this though anyone want to chime in?
yea idk where i read that...i forget the width of the 8.8 but the wj is either 63 or 63.5 im pretty sure...Originally posted by fullwidthxj191 View PostIf anything doing an 8.8 will be narrower in the rear. I don't see why going to a super 88 would make it wider, the housing itself is still the same.-Jason
99WJ 4.0
his original post says he needs a 5 on 5 bpOriginally posted by customcreationsllc View PostThe JK rubi axles jumped up in price and the JK axles are 5 on 5 bolt pattern.
At this point I would go with the 8.8 or go right to 1-tons.
i have the dana 35...and its longer than an xj, tj, zj's dana 35 which i think would make the shafts even weaker...
no i probably won't beat on it so much, but when im 200 miles at rausch from home or whatever the distance is, it will be more comforting lol...
and if im going through all the $ and effort to gear and lock id rather put it in something useful...-Jason
99WJ 4.0
