And I think I may have fooked something up.
I basically pushed the t-case and trans up at least an inch or two to make the crossmember higher clearance than stock. Well, I took it for a test drive and the first thing I noticed was there is way more vibration/noise through the floor than there was before. I figured this was just because everything was much closer to the transmission tunnel, and brushed it off.
Went to try and shift into 4-lo and it's no good, either it stays in 4-hi or shit starts to gind and knock.
Did I just fuck up the t-case linkage, or could there be some other ill effects here from everything being pushed upwards?
This is on the ZJ btw.
