what would you rather run?
  • what would you rather run?
    short arm tj or soa yj
    go!
    short armed tj
      soa YJ
      99 XJ on tons and 40s....
        YJ so you will actually wheel it
          YJ
            ran both. they have pros and cons.
            yj is simple without track bars and death wobble, rode better on the street and flexed good. tj will be nice in the woods but yj is more predictable off camber and on hills. if you can do the springover right... do it
              yj
              #becauseJoeNitro
                Originally posted by JoeNitro View Post
                yj
                why?
                  cuz ive wheeled a tj and i dont like it.
                  #becauseJoeNitro
                    lawl
                      I'd wheel this with short arms
                        did i mention the tanks a tank.
                        both r gonna end up costing the same in the end.
                        soa yj with welded/geared/disc'd 8.8 rear and lockright/geared/ hp30 front, sye, on 36's. yj steering with jb4x4 highsteer bracket
                        short arm tj with crown vic/xj spring lift/lower control arms, d35 open/no gears drum, lp30 lockright/no gears on 33's
                        honestly leanin towards the tj. i've always wanted one. easier to build, winter months coming up it'll be alot nicer to drive and i've already had 2 yj's. nice to try something different. and down the line i could throw an 8.8 in/ weld it, gears + jks 1.25 body lift and bump up to 35/36's if i wanted. unless i won the lottery tho i can't justify droppin 2g's on long arms for it so it'd never happen
                          Per the specs the YJ looks like a no brainer to me. Plus a YJ offers cheaper "expansion" as far as moving up in tire and axle size. Where TJ's get expensive very quickly with bracket kits and such.
                          Bent Fab Evo4 Rockwell Buggy
                          2011 Silverado 6.2L LT
                          2009 Pontiac G8 GT
                          2004 Z1000
                          1999 TJ
                            x2
                              how many SOA YJs have you wheeled?
