It wasnt hard. Just draw a line and keep to it. What do you plan on using to cut it?
tire help
its really easy to trim and it can be pretty close to exact you use a line left behind by the flare.
edit: caleb beat me to it. I used a grinder at first then tin snips later on. the tin snips worked nicely.1993 XJ sport 3.5" rustys 33" MTZ's armored.
Id try it with an angle grinder or die grinder first because it will be easier to work with. A sawzall might catch the fender and bend it.-Caleb
ok any ideas so make it look better and what if i get bushwacker fender flares will 32s fit with those on my 3 inch lift ?Originally posted by Bigbike View PostId try it with an angle grinder or die grinder first because it will be easier to work with. A sawzall might catch the fender and bend it.
I personally don't like bushwackers on XJs. Fenderless XJs look a lot better than anything ive seen except maybe Flat fenders but thats another story. Just cut them and throw some fender trim on it. I think its fender trim.-Caleb
Most of offroad driving is about drivers skill. We say go bigger tires because you will want them very soon. If you do 31s and learn to wheel in harder spots then you will know what your doing when you move up to bigger tires.-Caleb
32s aren't going to be much different from 33s power wise. Like Dan said your jeeps isnt a formula car it wont go that fast. My jeep can go "fast" but im not a fan of it shaking at speeds and the milage. Some people dont like 33s with stock gears but some cant stand it. I know plenty of people who run 33s on stock gears(me included), I dont like it at all but its def tolerable and I have 3.07.-Caleb
well 32s should be better than 33s with stock gear right i dont know what gears my 88 cherokee limited has ill have to look it up.Originally posted by Bigbike View Post32s aren't going to be much different from 33s power wise. Like Dan said your jeeps isnt a formula car it wont go that fast. My jeep can go "fast" but im not a fan of it shaking at speeds and the milage. Some people dont like 33s with stock gears but some cant stand it. I know plenty of people who run 33s on stock gears(me included), I dont like it at all but its def tolerable and I have 3.07.
. IN SHORT....i'd get 32's.
