lack of power
  • lack of power
    had trouble on startup due to a bad regulator, but theres also the issue that when im at cruise speed or accelerating at normal pace the jeep will suddenly lose power. it doesnt want to stall, it almost acts like you let go of the gas(while on the gas) but it stumbles and sometimes a little misfire knock is heard. to stop it from doing that you can either wait it out a few seconds or stomp on the gas and it stops. i changed the fuel pump because it needed a regulator anyway and i figured maybe there was something wrong with the check valve, but afterwords all that was fixed was the startup pressure, relieving me the need to crank it over 2 or 3 times before it caught.
    any ideas?
    edit: oh it also only usually does it a few moments after startup and get a little ways down the road
    1945 Willys-Overland CJ2A
    bump on this, it got worse tonight idle was down to like 300 and when on the gas it was just rolling forward with short bursts of accel. anyone with ideas i really need this shit fixed
      Sounds exactly like what my tj does. from what i can tell it could be plugs and wires and all the stuff that goes with that or it could be the injectors
        sounds like mah truck... i still have not figures it out and have had it at my mechanics for a few days before. still nothing.
        2013 F150 fx4 (Tow Pig/DD)
        • 5.0 with the 3.73 option
        2003 TJ Rubicon
        • 4.0/42rle/np241or
        • 5.13's
        • 33” BFG KO2s
          yeah i was thinking ignition or injectors after the fuel pump didnt work. its all new plugs wires cap and rotor in there im thinking maybe the coil might be on its way out?
            check the injectors first i would say
              try cleaning your throttle body and running some seafoam through the brake booster line.
                that second part confused the shit out of me for a second haha.
                  tuned it up? aka new distributor, coil, and plugs?
                  2001 TJ
                  2001 Tahoe
                  2013 M3
                  1986 R65
                  1997 Blackbird
                  2013 R1200GS
                    when was the fuel filter last changed? might have stirred up sediment in the tank when changing fuel pump
                      how would one complete such a task?
                      already did a tuneup, not a new coil tho, i gotta ohm out the old one first
                      the fuel filter is in combination with the pressure regulator, and i changed the whole fuel pump assembly so it came with a new pressure regulator and strainers
                        Get mustang injectors that way if it wasnt it youve upgraded lol.
                          not sure that works for the newer cherokees....
                          but that was the exact mentality I had when I did them on mine
                            With my limited engine knowledge and decent amount of common sense... if its only happening on startup, and im assuming you mean cold startup, then it sounds like a problem with ignition that is otherwise unnoticeable when the cylinders are hot. Maybe check timing?
                            I just think issues in the throttle body and injectors would be a constant issue, not only when just started.
                            2001 TJ
                            2001 Tahoe
                            2013 M3
                            1986 R65
                            1997 Blackbird
                            2013 R1200GS
                              it sounds like maybe something to do with the computer, but i would try what was stated above, some plugs, cap&rotor, and maybe a coil....
