alright so i've done some searching and i can't find a straight answer anywhere......
Will ZJ 44 brakes be a direct swap onto the XJ 44???
and if not, is there any rear 44 disc brake set-up that can be easily and cheaply swaped in??
i read a thread on pirate, where you use zj dana 35 discs, and you just fill the exsisting bolt holes with weld and drill new ones to bolt it up to the xj 44. i just wanted to see if there was something easier i could try before going about beginning this project. thanks.
