ok so I got my tcase, correct splines, out of a 94 XJ, for my 98 auto Tranny.... put on my SYE, and today attempted to install it. splines up just fine, and slides on good.... but it doesn't slide on all the way. It appears that the tcase input does not allow the tranny output shaft to slide on as far as it needs to go..... there is a little ridge on the end of the splines on the tcase causing this..... it looks like my only options are to either cut the output shaft down to size or buy the right input for the tcase, can anyone tell me wtf the deal is with this thing? And no I didn't try putting the t case on before putting the SYE on..... I really didn't foresee this happening
Transfer Case doesn't fucking fit
if there arent any splines or anything important looking i would cut it down to size99 xj, 3" RC, 35" BFG AT red labels, custom rear bumper, SYE, armor, Hellas, waggy 44's fr+rr, 5.13's ,lunchbox lockers fr+rr, rear disk conversion,rock crusher covers frt+rr, beefy homemade 1 ton highsteer setup
how much do you need to cut off ? it it isnt that much, cut it down, deburr the edge of the splines and run itup to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
You said you have another T-case just swap the SYE over it will take less time than cutting the splines.
New spline inputs are over $100.RCrocs #123 Brown CJ-5
i'd hold a steady hand, and mark shaft with a sharpie/ piece of tape etc that goes all the way around the shaft. take a cut off wheel and cut as close to the sharpie as you dare, then take a flap disc and work the rest away till the no meetal is left up to the mark you made . maybe there's an easier way.up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
