Will my tranny blow if I change the fluids in it? Someone in the forum told me a while back that it might but I want better input. I have a AX-15 tranny with 127,000 on it. Thanks for the input.
Need some technical support on my tranny.
hes talking about the theory on changing the fluid of an AT but thats still wrong, its just that theres no clutch dust to help the band friction so the clutch bands slip with the fresh fluid, nothing blows up. but this in no way is relevant to a manual transmission.2005 Jeep Wrangler Rubicon Unlimited
1945 Willys-Overland CJ2A
I think its the flushes that can cause the issues. If the fluid hasn't been changed in a long time it builds up junk on internal components. When you do a flush you stir all that shit up and it can supposedly jam up your valve body. But again this is with an automatic.1993 XJ sport 3.5" rustys 33" MTZ's armored.
tis the truth, it happened with the GMC. We did a tranny flush in our garage not knowing this and 300 miles later kaboom. You really only have to worry with Automatics. Manual trans are fine to doOriginally posted by wannabejeep View PostI think its the flushes that can cause the issues. If the fluid hasn't been changed in a long time it builds up junk on internal components. When you do a flush you stir all that shit up and it can supposedly jam up your valve body. But again this is with an automatic.P8R
The only trouble you will have with changing fluids (and this only pertains to an AUTO trans) is when you dont change the fluid for a long time. THis is because the fluid gets burnt and dirty and the trans breaks in with the bad oil. When you change it, the trans cant operate correctly
i heard using this stuff called sodium silicate is really good for the tranny. look it up
Thanks all some one on sis told me it would blow it up a while ago so i never did. Wannabejeep told me so. http://sisoffroad.com/forums/showthr...highlight=lube95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
Who cares if he told you that? You did not post up if it was auto or standard he assumed it was probably auto.Originally posted by 95jeepYJ View PostThanks all some one on sis told me it would blow it up a while ago so i never did. Wannabejeep told me so. http://sisoffroad.com/forums/showthr...highlight=lube1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
Makes sense. Once again thanks everyone for your help.Originally posted by Bigbike View PostHe might of presumed you have an auto since you didnt specify.
