I am looking at a dirt cheap 5.2 zj tomorrow. The owner says it needs a freeze plug. What kinda pain in the balls will replacing that be, on a scale of 1-10. AND, if it isnt leaking too bad should it be ok to drive 45 mins home?
Freeze plugs...
yeah, they are easy to replace but a mother father to get too properly. if its a small leak you can try a "stop leak" type product and see if that works, or at least bring some for the ride home. to replace you hammer then in then pry them out"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
Originally posted by grundlepunch View Postyeah, they are easy to replace but a mother father to get too properly. if its a small leak you can try a "stop leak" type product and see if that works, or at least bring some for the ride home. to replace you hammer then in then pry them out1993 XJ sport 3.5" rustys 33" MTZ's armored.
Originally posted by clean4drxj View Postis it the freeze plug or the block? it's something you'll have to checkout, alot of people around here don't believe in coolant flush/replace and it has a shelf life like anything else...Originally posted by Ktmracer419some people choose video games
Originally posted by wannabejeep View Postfuck stop leak. Yeah you may jam up your freeze plug leak, but you'll also jam up your radiator and kill your thermostat. Basically you'll be jammed up till next week.
as far as the rubber plugs.. dont even think of using them, they will work for a little while but give it time and that shit will be leaking right out.Originally posted by Ktmracer419some people choose video games
Originally posted by justtorchit View Postyeh.. def. dont dump that shit in.. stuff costed me a radiator, therm., took months to get the crap flushed out...
as far as the rubber plugs.. dont even think of using them, they will work for a little while but give it time and that shit will be leaking right out.dirty30
Originally posted by wannabejeep View Postfuck stop leak. Yeah you may jam up your freeze plug leak, but you'll also jam up your radiator and kill your thermostat. Basically you'll be jammed up till next week.i have helped some one do them on a dodge ram with a 5.2, and it wasnt that bad, just awkward positions
