I'm trying to figure out what size rear bumpstops to order now. When the rear tire completely tucks and mashes up against the quarter panel/fender i have about 6 inches between the axle tube and the uni-frame. My old bumpstops are gone so i can't measure from that point. The stock bumpstops are about 2" so i figured i'm going to have to buy a 4" extended bumpstop that requires me to figure out a way to mount it because it doesn't use the stock mounting points. Anybody got any info or ideas what to do?
rear bumpstop length?
if you can't weld
www.dpgoffroad.com
they have adjustable bumpstop plates.
i run those with 37" tarz and quadratec 4.1" bumpstops and 2 plates installed.
I am trimmed to the spot welds and folded over and they are perfect like that.
I want a lil' smoother dampening effect though (needs moar lift) so i plan on running a poly bumpstop from the bottom to hit the rubber on top for a more progressive bumpstop
