throttle body upgrade?
  • throttle body upgrade?
    i have a 98' 4cyl tj, would it be worth upgrading to a 4.0 throttle body? i've searched around and i hear good things.
    if so, what year throttle body should i look for? and what do i have to do to install it? thanks.
    oh, and would installing an electric fan be worth the trouble?
    http://strokedjeep.com/index.html
    do that. increases throttle response quite a bit, and gives a lot more tip-in. efans take the load off of the motor, which will make it rev freer most of all, and maybe free up 3-5hp.
      you'd be looking for 94 to 05 any jeep vehicle with a 4.0 most all of the throttlebodies are the same..
        thanks so much for the advice. i'm looking on ebay for a TB, unless you have a better idea
          look around here, junk yards, jeep forums,craidslist ect...
            i found one on ebay for $30...is that a good price?
              I got a whole intake from a 4.0L out of a 96 XJ I think it is missing the IAC valve
                how many sensors are on your throttle body ? older tb's have 3 sensors while older one's have only 2 bolted to it.
                  The 4.0 throttle body is a good move, try to find one out of a similar year tj with a 6 it will bolt right in and not cause any emissions issues and all the sensors will match, im looking to do this to mine soon.
                  The electric fan isn't worth the trouble for a bump of only 5 or 6 hp. Just save your money and energy and grab a chip instead. The stage I chip will bumb you up 10-15 may be 20hp and doesnt require any engine mods and all you do is plug it in and drive.
                  We both should have just got a 6cyl to begin with and saved ourselves the trouble.
                  99 TJ 4cyl, 4" short arm, 33" MTZ's, JKS quick discos, smittybilt front, rear & rockers
                  Work to be done: Clayton long arm, ford 8.8 rear locker & 1 ton
                    i don't know if they were sensors but i seen 3 black pieces that plugged into it. are those the sensors you're talking about?
                    oh and would a 4.0L TB out of a 96 XJ fit on a 2.5L 98 tj?
                      lol if i only did the research and knew how much difference gettin a 6cyl would have been, i would have waited but i still love my ride
