6 in lift help
  • 6 in lift help
    So lets say i have a stock 97+ xj and i'm lifting it 6 inches. What else do i need to do to beside...
    SYE + Driveshaft
    EX. Brake lines
    oh and i just would like to know what i have to do right away being its my dd and i will not have the money upfront to do everything i want. but it will come
    4x4 Station Wagon...
    Control Arms, Tracbar, and few other things i believe
    In my opinion save your cash and get a complete kit and do it all in one shot.
      shims for the rear, should upgrade the steering, like otte said get a good kit with everything, claytond kit is an awesome setup
        what exactly is a shim?
          goes between the spring and leaf to help with pinion angle
            im sorry i'm still confused.. could you explain it a lttile more
              The shims raze is talking about are degree shims that go between the axel and leaf spring to help with pinion angle. This is to help keep pinion angles good an reduce vibes in the driveline.
                pinion angle is where the pinion on the diff has a "line" to the transfer case. for easy reference on this it is the angle of the drive shaft. when you lift it the pinion will not point at the transfer case which will cause binding on your ujoints cause them to blow/ vibes. so you have to get the pinion pointed towards the transfer case by using a shim. better? im am not used to having to break it down sorry
                  haha no that was helpful thanks
                    is the tracbar necessary also. or can a run stock for a few weeks
                      i would def buy one right away or get a good kit with EVERYTHING in it, claytons kit and rubicons both have them in it
                        yea i, not getting a full kit because as a 17 year old camp counselor its not in the budget. im picking up bds coils and RC full packs for 250 and going form there. im planning on running porc SYE with XJ front d/s and picking up used shocks and control arms
                          definitely get a trac bar before you put the lift on
                            is the new track bar just going to be beefyer
                              it will be longer so your front diff is not pulled over to the drivers side keeping it centered
