How do i install stock t case skid... ASAP
  • How do i install stock t case skid... ASAP
    I picked up a stock t case skid today and cant figure out how to bolt it on. I cant see where it bolts on but dont see how the bolts fasten.. ???
    4x4 Station Wagon...
    go to a GOOD hardware store, not home guido, not lowes
    and pick up some nutserts
    if you went to a good hardware store the guy working there should be able to tell you how to install them
    be sure to measure the holes in the unibody, i forgot what diameter they are
      what about the cross member side.. does the cross member open up when you take it off?
        i used self tappers on the unibody side, and gr8 nuts and bolts on the x member. took 15 mins.
          but on the x member side. do you take it off? how do you get the bolt through or to the bolt head?
            there are holes that line up with the holes on the skid, just fish the bolts/washers/nuts through.
              i used nutserts on the crossmember and unibody
