Im in the midst of switching doors because mine failed. The last torx head bolt stripped of course, any tips to getting the bolt out? I have new bolts that arent torx head as well. Any Ideas?
door hinge/torx head question.
Drill into it, and try using an extractor?Shane "The Bag" Carlson
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
Thats what I was thinking of doing. Im just saving the hinges so no biggie. Im also making it pass. side doorless during the transfer. Thanks you guys.-Caleb
HEAT HEAT HEAT HEAT HEAT.
Use a goddamn torch for christ sake. Head the head up for the rest of them and they will come out. Get it red hot. They are torx heads for a reason.
For the one that stripped, you might have to cut the head off or better yet, go doorless and drill it out. With the door off, you'll have easy access to it.sigpic
x2Originally posted by Buffalo Phil View PostHEAT HEAT HEAT HEAT HEAT.
heat brings the magic.
i dont know how you and will were able to cut the hinge without removing it, but i can get about 9/10 of the way then i run out of cutting wheel (using the dookinest reinforced wheels at the guido too)
Wait...If you remove the entire door via cut the hinge aka doorless mod, you'll have access to all of the torx head screws.Originally posted by Ktmracer419 View Posti dont know how you and will were able to cut the hinge without removing it, but i can get about 9/10 of the way then i run out of cutting wheel (using the dookinest reinforced wheels at the guido too)
Or, you could do the doorless mod, and then modify the hinges on the new door and have it drop right in. No need to go after the torx.
Or maybe I am just a confused child speakin on this internet machine box.sigpic
I got the door off. I did use the acetylene, and i got the other torx heads out with a lot more ease than this one. Now what is the easist way to get the pin flipped?-Caleb
HEAT FOR THE FUCKING WIN.Originally posted by Bigbike View PostI got the door off. I did use the acetylene, and i got the other torx heads out with a lot more ease than this one. Now what is the easist way to get the pin flipped?
Whenever a bolt it tight, JUST TORCH IT.
Andy would know.sigpic
I got the hinges back on and what not. I need to cut the bottom lip thing i think its holding me back from putting the door on, well part of the reason. I believe i need to bend the pin to make it work too. hopefully i get this stuff done on Thursday.-Caleb
Good luck dood
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
