urgent help
  • urgent help
    On the drivers side the spindle is pretty much seized to the caliper mounting bracket. I've tried beating the caliper bracket off, i've tried hammering a chizel in between the two. Any other ideas or just keep on keepin on until i get this bitch off?
    heat?
      nvm, seems like every time i ask for the help the jeep says ok i'm gonna fuck with him and make it easy as soon as he comes back outside
      mods may delete now
        then keep asking questions maybe it will fix its self
          im not deleting shit
          here is a useful tip for next time:
          stick a socket between the axle housing and the ear on the outer axle shaft.
          turn jeep on and turn into the socket
          has worked on every dana44 spindle and dana30 hub i have ever tried it on.
          if it doesn't pop it off, it will at least crack it free.
          if the axle isnt under the jeep, i have had similar sucess with the above, but by hammering on the outer knuckle
            Take out the 3 mounting bolts that old the unit bearing bearing to the knuckle. Install them in a couple turns. Hammer on the heads of the bolts and the unit bearing will come out. If you dont want to damage the 13mm, 12 point bolt heads, put a socket on it and the socket will be damaged but not the bolts. Ive done that and I've always got those stubborn bastards out.
              Nevermind, you dont have a Dana 30.
                you are wise beyond your years my child...
