tyaz
  • tyaz
    When I was at the dealer on Wednesday dropping the Jeep off again I asked the guy about what things can void my warranty. He told me messing with the engine was a big no no and then he mentioned putting bigger tires on could cause all sorts of issues with it.....I find this hard to beleive since it seems everyone here runs larger tires. He said it can mess up my spedometer which makes sense but then he said it could mess up the differentials.
    Seems like no one here has major issues with large tires...wtf is he talking about it causing all sorts of issues???
    2009 silver JK - destination beachy jeep
    J10 project do want.
    "attack life. its just going to kill you anyway"
    hes a dumbass. he probably means that with bigger tires ur more prone to breakage but doesnt it have a 44 in it? also yeah, it will throw off ur speedometer a bit but nothing that should void ur warranty. seems like BS to me.
      well some warrenties these days are strict as hell. like if you miss a scheduled oil change it voids your whole warrenty and your screwed. but as for breaking and whatever I think you are fine. but if you throw on a set of mud tires in the same size or even a little bigger I cant see why it would void your warrenty. but I would ask first
        on some vehicle warranties if you modify anything you are fucked
        and your traction control will be pretty much useless with bigger/ grippier tarz
        larger tires puts more stress on everything.
        but what they dont know can't hurt em
          i was gonna buy a jk when i worked for chrysler/jeep/dodge. i asked my service rep if i put a lift and tires on would it void the warrenty and he said he'd still warrenty everything except the suspension(obviously). so i guess it depends were u go. find a dealer wtih a cool service rep
            RckymtnTJ had an 06 TJ that he put a lift and 35's on. He had work done to the motor under warranty. I would imagine the service guy was just telling you that to cover his ass.
            2000 XJ
            2000 A.C.E. 750
              the only thing i can see it affecting is the traction control like sam said
                When i was in moab for EJS09 i wheeled with a JK thatwas open open with traction control and 35's.
                It went up cliffhangerentrance/exit no problem... the traction control worked awesome!!! the jk's traction control, when it senses slip, applies brake to the wheel slipping.
                So when he was comming up cliffhanger he started slipping and after a few seconds of slip, the traction control turned on and went right up.
                So yes...it might affect the life of TC,due to added strain on drivetrain of larger tires, but as proven by this, it does not hurt traction controls ability to work.
                2013 F150 fx4 (Tow Pig/DD)
                • 5.0 with the 3.73 option
                2003 TJ Rubicon
                • 4.0/42rle/np241or
                • 5.13's
                • 33” BFG KO2s
                  it does not apply brake to the wheel that is slipping it pulls power from it and diverts it to the other wheel.
                    okay...oops... screwed that up.
                    However it still works and it showed to work well. not as good as a locker but, way better than open
                    2003 TJ Rubicon
                    • 4.0/42rle/np241or
                    • 5.13's
                    • 33” BFG KO2s
                      i believe some systems actually apply the brake also
                        yes it does. its an ELSD system- standard clutch typle LSD diff with the ABS sensors monitoring wheelslip. wheel slips, the brake stops it and that forces the LSD to send power across the axle.
                          Im not 100% on the not applying brake. some jeep TC systems apply brake to the wheel and some divert power. it depends on what you have in the specific vehicle, either is an option on almost all models.
                            time to /thread
                            keep your stockers in the garage courtney
                            if you ever need warranty work done, u just put em back on
                            run the muds.
                              time to /thread
                              run the muds.
                              X2 Thats exactly what I was thinking.
