Its getting annoying and a bit embarassing lol my jeep is squeeling bad and loud my dad always yells tighten your belts but how do i go about doing this thanks ahead of time for info
I believe you have a serpentine belt. Check to see if it has more crack than Harlem. If not, spray on belt dressing you can get at any parts store. If it truely is loose, you will need to replace the tensioner.
Not on a 95... there is an adjuster bolt on the PS pump bracket. Loosen the PS pump bolts and tighten the adjuster. I would also go invest in a FSM or a Chiltons Manual, they have good pictures explaining basic stuff like this
