Only in 4 low under load, the case will just ratchet it sounds like, tires dont turn. Put it in 4hi (part time or full) and put it under as much power as you want, crawling, driving, whatever, and it never happens. The Jeep has no hack n tap or SYE otherwise, it has a 1" Tcase drop, and stock driveshafts front and rear. 3" lift.
What would cause this? I would assume stretched chain but it doesnt ever do anything else relating to that (no noise of it sagging on the case and dragging, no skipping at all under load in 4 hi, so on.) It has never been wheeled hard or thrashed..it was bone stock 2 years ago and has only seen light trail use on thin 32s since.
