opinion needed right meow
  • opinion needed right meow
    i'm ordering a u-bolt style pinion yoke for my d44 right now but i'm wondering if i should get a 1330 yoke and 1310-1330 conversion u-joint for the driveshaft
    http://completeoffroad.com/i-124195-...-1330-26u.html
    http://completeoffroad.com/i-123005-...onversion.html
    or should i just get the regular 1310 yoke and u-joint
    get a 1310, as long as you fix your pinion agle shiat u shouldnt be breakin ujoints/yokes on your setup on the driveshaft
    'tis mah opinyon.
      Do you need to get a diffrent driveshaft or yoke or w/e when you swap a D44 in?
        i'm running a front xj shaft and am replacing the stock strap style pinion yoke with a u-bolt yoke. just wasn't sure if these conversion u-joints are any good or if sticking with 1310 would be sufficient
          stick with a 1310. abundant extra's (people carry them as spares) and in parts stores.
            sounds good guys, thanks
              google the teraflex yoke, i think its cheaper.
