full width with allied bead locks
  • full width with allied bead locks
    trying to order some beadlocks and get my ton build started im wondering if any one has run full widths with the allied bead locks at 3.5 inch of bs i think it shouldnt be that wide but im curious to see some pics of it
    97' zj
    2012 surbra imperza DD
    Uhh that'll be insanely wide. Rob95xj or whatever on Naxja has that setup and its crazy wide... I think
      I ran that back spacing on h1's with those axles
      Your front tires won't be under the fenders
      And cops will pull you over..... ALOT.
        Isn't Dan running that backspace?
        97 XJ.
          hahah. military H1 wheels?
          also do stock H2 wheels suck the tire in further when you are running full width axles on an XJ?
            Dont you worryy I have fenders that will cover
            97' zj
              with 3.5" BS Im 84" outside to outside with 39.5x13.5's on 17x8.5" wheels.
              Its pretty wide. I liked 4.5" BS. about half the tire was out of the fender, maybe a little more. Wanst too bad. H2 wheels are 5 5/8" BS.
              3.5" BS
              4.5" BS
                https://www.wildwestoffroad.com/cata...-8/prod_7.html
                Maybe ill get a 5bs rim once its in ill see about clearance and all that jaz
                97' zj
                  Looks good. If you come over when its done you can try my wheels or Reid's and see how they fit.
                  97 XJ.
                    this was mine w stock h1's w 7" BS
                    how it sits now w 4" BS, just a little narrower than Dans...
                    and i havent gotten pulled over once...but then again i dont live in Fairfield,haha
                    99 XJ on tons and 40s....
                      bump is there any reason why i shouldn't run a 5~6 bs wheel with full width tons? besides my hub sticking out? because its spring and i want to wheel and need rims
                      97' zj
                        buy my wheels, because you will save money, and wider is cooler
                          wide is not fun for tight trails and i dont wanna run 40 i wanna stay with 37's the wider i go the biggger tire i need
                          97' zj
                            No reason not to. If you have a front locker run drive flanges and dont worry about the hubs. That was the only problem I had.
                              Andy welded it should i add more weld and put flanges on?
                              97' zj
