It's happened before just with different symptoms;
1. Power is fine and the started spins
2. All fuses and relays have power
3. No cluster movement when the ignition is switched on
4. Check engine light does not turn on with other lights when ignition is switched on.
5. I do not hear the fuel pump when the ignition is switched on.
I didn't try and pop start it or check for spark yet but last time this happened it was the crank positioning sensor, and the time before it was the switch in the column that went bad. The weird part about this instance is that the check engine light doesn't come on with the other lights in the gauge cluster.
I am at a loss right now. Any thoughts?
